rear wheel tracking,
well guys, removed my hicas and need the tracking doing, just wanted to know what is a good rear camber and toe setting? and would after market alloys effect the alignment?
thanks in advance :)
Personally I'd stay with a stock setting. Your alignment place will recommend what they can set it to. It also depends on what wheels/tyres you have fitted. You might want to dial in a little more negative camber, especially if you track it.
I think that the stock settings are best IMO. You'll get more even tyre wear too.
Bear in mind that you don't have a huge amount of adjustability with stock rear arms and none with stock front arms.
