Pod holders
Lee its not worth getting second hand ones just by new ones from either Mike or Luke
+1
Used ones will be as old as yours in most cases and just as brittle.
Make sure that you order the screws for the hazard warning light switch. They are slightly shorter than all the other binnacle screws....the reason most are now broken is because people refit the 'slightly' longer screws which end up cracking the mounts.
