protoj ·
Hi Guys. Looking to change out my front bypass hoses as I suspect a small leak might be from there.
Just wondering if its a fairly straight forward job to do?
Pull the rad and fan to get proper access and take it from there?
Any help gratefully received!
Thanks. :)
