Na tt rear hubs and rear upright
Hi today me and my mate removed subframe bushes from a na subframe also split the hubs from the alloy uprights . My question is will the tt alloy up rights bolt to the na hub carrier .i can't see any diffrence in the uprights . The reason being is the tt uprights I have have been polybushed .i know the tt ones will have a ball joint that will need moving where the hicas arm link to but that's no big deal . Anyone done this swap thanks Taff.
if i remember right the Hub carrier is the same just that the TT has the ball joint in the rear track control arm of the carrier unlike the NA one uses a Bush .. you can swap over
and reuse your Hub n Bearing
Edited by MarkDerby
NA rear bearings have a different part number, I'm not too sure that's the case. They maybe interchangable though, but they are different.
Uprights are the same except the hicks joint
Tt rear hubs, driveshafts etc are not
Be aware there is also a dust seal for the driveshaft, they need to be swapped also
Personally I would be keeping the rubber bushes. I have experienced poly bushes in both my old z32 and s14, both very similar rear suspension and in both cases it made the car worse.
