brake help
Me again :/
Noticed my front brembos need changing as they have worn right down and it's started high pitch squeeling.
Tried to find some but I can't aha. Only the full kits for sale
I'm sure they are 320mm
anyone any ideas? Thankyou
Found something on ebay... my disks are 324mm I believe. Drilled also... 350z front drilled disks are 324mm aswell so I may have the conversion on my car?
Anyways. Would any 324mm fit or will they have to be brembo?
It doesn't matter on the make...it just matters that you get the correct size and hub fitment. I'd recommend not getting cheap discs though as they will probably just warp if they are budget discs.
Ah alright mate thankyou and no I think they are silver
Hmm. Could you take a photo of the caliper from the top and bottom? Have you noticed whether the caliper is bolted straight onto the hub or whether they're attached via adapter brackets?
Yeah will get a picture up tomorrow mate :)
