Hi, can anyone help ,I am looking to uprate my standard engine water cooling Radiator ( my car is an Auto but I do not use the standard radiator oil cooler) ) , howeverI want to retain the use of the original fan cowling and mounts, can anyone help.
Sayers 07929159828
Japspeed? Should still be able to use the cowl within some faffing, the bolts might not line up perfectly.
Your oil cooler is already seperated?
Why are you upgrading, cooling issues?
The Koyo radiator will work with fan cowling and lower mounts without modification. The stock bonnet strut brackets
will need to be swapped L/R so they clear the end tanks and notched to grip the radiator top lip (there are also
aftermarket brackets available for straight fit).
thankyou , anyone know where I will get a koyo or japspeed radiator please
