Hi guys, really could do with some guidance on an issue I have at the moment. Have been Googling it a lot but so far not able to come to a firm conclusion.
CAR
'91 Jap Import 2+2 300zx TT
ISSUE
Noise coming (I believe) from the rear of the car.
Noise is consistent with road speed, not engine speed.
Starts around 20mph and gets louder with speed.
Throttle and braking does not seem to affect the noise.
Turning left makes the noise disappear instantly, it returns when you straighten up. This is either a slight left at high speeds or a sharper left at low speeds.
Wheels are not noticeably warm/hot after a long drive
THINGS DONE TO THE CAR
I've changed the diff oil - this did not affect the noise
Fitted C-cups to the rear subframe mounts - this did not affect the noise
Inspected CV joints on drive shafts - no obvious issues, i.e. not split
Replaced the passenger side wheel bearing - this has not affected the noise
I've been reliably advised that the prop shaft bearing is gone, however I'm not convinced this fits the noise? (thoughts appreciated)
Car has standard suspension but is running negative camber on the back - despite the adjuster being all the way out
Any thoughts, help or similar stories appreciated!
CAR
ISSUE
Thanks.
