Cardiff area
Hi can anyone help I'm looking for a garage to check out a misfire I have on my 1997 300zx twin turbo it has had a lot of modifications made to it including piggy back ECU so I need a garage who will look for the problem and not just say the system needs to be put back to standard I have owned the car for 4 months and its been running great then last week it started to misfire I have changed the spark plugs and checked the coil packs which are OK but misfire still there
Please contact me with any info either about local garages or suggestions on things to try to solve misfire
Malcolm
Yup, Jimmer @ PowerZed is not far from you at all and the place to go.
ย
Does it have an Emanage or Unichip fitted?
Thanks for the replies guys does anyone have a phone number for Jimmer at PowerZed
Noz I take it that your asking about the piggyback ECU if so i really don't know what's fitted or how it works or what the advantage of having one is
ย
07725 886170
Thanks guys I will call them tomorrow and see if I can get it booked in for fault diagnostic
ย
There is no advantage to a piggyback ECU on the 300zx, the standard ECU is fully mappable. It was probably fitted due to your '97 Zed having a 16bit ECU and the prior owner/tuner not knowing how to map it.
