Hi I am new. I have a 1993 Z32 TT UK which I have owned since 1997. i am looking to replace various "tired" parts eg door and window seals. Firstly I need to replace both top door skin window seals. can anyone help.
  • Replies 27
  • Views 3.4k
Hi and welcome :thumbup1: very hard to get good second hand parts for these but if anybody does not come up with them you have the option of buying new from our trader Mike
http://www.300zx.co.uk/forums/forumdisplay.php?38-MJP-Eastern-auto
Or from Zcenter but they can be expensive.
http://www.zcentre.co.uk/index.php?page=shop.product_details&flypage=flypage.pbv.tpl&product_id=138&category_id=57&option=com_virtuemart&Itemid=7
Thanks. I think I need new as the rubber is very hard with no flexibility and is therefore leaking.
As well as the traders Gary linked too, you can try the US suppliers. Sometimes cheaper sometimes more expansive (post tax and shipping).
Try CZP, Z1, Rock Auto, and Courtesy Nissan.
Thank you. Very helpful. I used to get stuff from MJP several years ago but lost contact. Great to know he is still about.
Welcome! It would be nice to see pictures of your UK car. Mine is a '94 which I've owned since '98, so another
long term UK spec owner!
how many uk cars on here then ? my is a uk car seems pretty rare
Hi Andrew
Photo tomorrow. In the middle of putting the doors back together after replacing op window slider pins.
  • 1 month later...
hi i am having same problem with my cars door rubbers, i am going to florida for 3 weeks does anyone on here know anywhere in florida i could try for parts thx
hi is there any members on here from florida that knows best place to get 300zx parts from i am going there for 3 weeks thx dazzler
Hi
what is the exact problem that you are experiencing with the rubbers?
rubbers that go around the top of the doors are very hard so constantly lets water drip in when raining thx
Could you not get them shipped to where you're staying in Florida? I always get stuff from czp & bring it home.
where is CPZ it would be good to get them while i am in usa then bring them back myself
thanks thats just the info i require they will most likely ship to my hotel thanks again
Hi
I have had a similar problem. i found that the drivers door window was not sealing properly which was because the "stoppers" which prevent he windows from winding up too far needed adjusting slightly. it is a relatively easy job to do when it is explained to you. I also found that the door rubbers were making a noise when going over bumps. This was solved by rubbing them with candle wax. complete cure!
bryan
They're in Arizona. Z1 are in Georgia.
Welcome to the club brynova.
So is your issue fixed then? Was going to suggest taking them off and leaving in some hot soapy water for a bit
Membership No 0780
INSURANCE GOOFA
Hello again.
I have had further thoughts If the glass is loose or has any play in it when the door is open you will also need to replace the top window slider pin. Again quite easily done when you know how. £12 for the pin and a couple of qujd for replacement door card clips which will probably break when you take the door card off.
Bryan
Hi bird i have made it a lot better by replacing top slider pin and adjusting the stops for the electric window. it is not completely cured so i will try the soapy water treatment. thanks
