I am after a few bits and wasn't sure if anyone has tried successfully to use aftermarket parts.....??
1) Lambda sensors.... I was looking at Bosch replacement ones as they are apparently the OEM supplier.... part number 0258 986 504
2) Temp sensor for ECU - Nissan 22630-51E02 or aftermarket Intermotor
3) Temp gauge sender - Intermotor - 52540 / OEM - 25080-F3900
4) DET sensor - OEM or JECS
I wanted to hear from anyone who has tried either successfully or not to use non oem sensors and get some advice.......
I know some parts cause problems and Noz and others have had them fail or not function correctly so wanted to see if any of these are available and recommended by anyone....
Thanks....
1) OEM.
2) OEM.
3) OEM.
4) 1M ohm resistor.
1) OEM.
2) OEM.
3) OEM.
4) 1M ohm resistor.
Noel, are the OEM Lambda sensors Bosch ones?
I am due to start the new Job Monday and was going to order some through work if they are Bosch..... ?
I will get the resistor tomorrow......
Thanks for this Noel......
FYI OEM sensors I thought were only available from the USA anyway.
I might have a resistor you can have if you'd like me to have a look.
Membership No 0780
INSURANCE GOOFA
My post not good enough?:biggrin:
"Bosch Oxygen Sensors are the original Oxygen sensor that Nissan used in the 90-96 300ZX. Full 1 year warranty, Direct Fit. Please note that while the Nissan-branded versions are functionally the same, they have different part numbers for Left and Right. The only difference is the location of the plastic clips on the harness, and they can be adjusted to fit for either side. These sensors will fit all Z32s, 90-96, NA or TT, for left or right sides."
Courtesy of CPZ.
I'm curious if the Bosch O2 sensors are any good. Sould be if they make th Oem ones
Membership No 0780
INSURANCE GOOFA
Hi Bigh.... ConceptZ list them as Bosch 13091...... so should be able to get hold of some here through work......
Thanks Lonezedder.... I was reading and listening.... lol
Yes Lee ...... going to look and see if I can order some in at work.... lol
Edited by veilside01702
Let me know the cost mate. Did you want me to look and see if I have any resistors?
Membership No 0780
INSURANCE GOOFA
