Engine change and respray
Well the tt engine here so 1st job compression test on it if all ok with numbers I'll start breaking the engine down and replace gaskets and seals new injectors and hoses also the candy paint here looks nice just waiting for the rest to turn up and got too pay for some gear next wk happy days
  • Replies 161
  • Views 16.1k
Looking Good Ted....... I must get up to yours when I am back on the road...... Been promising to meet up for a couple of years now........ lol
Well going to try stuff today polishing wise if it works great I'll put photos up if not oops I wont haha
Ok mate, don't keep us in suspense! What are you polishing out of interest, hope it's something from the ZED ;)
Looking good Ted, but may i make a suggestion.... I too polished my cam cover pipes as in pic above, but after a while they tarnish and oxodise and will look awful after a few months, i would paint them as im am going to with mine. They will not stay looking that good for very long lol, even if you try and keep polishing them.
I don't mind you makeing the suggestion bud I'll see if I can fined a good chrome paint to go on
The candy red really seems to catch the sunlight Ted is it like that in real life or just how the photos are?
No mate that's how thay are even did the rockers again but in the candy some better photo baz image.jpg
You resprayed your grass too!
Haha yea and I got my ear bent for it, and using a saucepan thought it was a old one well it is now
Now Iv got a dilemma still no turbos 4 more wks prolly tunnel her next wk and I'm off for 9 days the wk after so do I go with my engine and pull her so I can do the respray and put that back or miss the summer and wait decisions decisions
Right started putting the power stering pump on damaged bolt nice now the question is can I use my n/a power stering pump instead of a tt one image.jpg
If you have your hicas removed you can use the NA pump, you will also need to do something with the pulley or belt, cant remember which as the TT pump is slightly prouder/bigger.
Cheers bud bloody engine starting too bug me now
I have an NA PAS pot.....
Cheers si but I'm ok with the pot it's the pump that given me a headache
Going to do a compression test today and put numbers up with photos to see if all good also paying out for new front and rear vented discs and sorted some other turbos so paying for them too that's my pocket money spent this month
Right did the compression test 1=25. 3=25 5=25. 2=25. 4=30. But 6=0 but there compression there ?image.jpg now am I stuffed here and it was done by hand
Edited by ted
Best compression results I've ever seen.
A fresh TT should be around 180psi per cylinder I think
You can't do a proper compression test by hand.
Edited by Noz
Take out the fuel pump fuse, turn the engine over with wide open throttle for at least ten revolutions lol
image.jpgWell put some oil down the spark plug now got compression back apart from no 6 but gone from 25-30 to 50 on the 1st turn of the ratchet
