original boost solenoids
Why lee?
If your not planning on maintaining stock boost you won't need them. You can even plumb up stock without a controller you will just have no safety boost, if that's a problem.
If you negate them and plumb straight to the Wastegate act you will get 7psi, unless you still have the little brass restrictor at which point you will have 9psi. The solenoid merely bypasses the restrictior lowering the pressure to 7. So I wouldn't get to worried.
there was a perfect pair in the haul you got off me mate
Yeh,
Most of the parts I left at Lee Dent to built my new engine then when the spares came back up
that wasn't used I left them at the garage not knowing they were there and eventually they got
binned thinking it was a box of things that wasn't of much value and that I didn't need.
My dumb luck.
im sure i have another set on an engine im taking apart if ya want them ?
