Hello everyone for some reason my battery light and engine check light dont light up when ignition is turned on,checked bulbs and there fine.:sweatdrop:
thanks for that ,but its very odd how battery light and engine check light arent working
  • 10 months later...
Hello everyone,i have a strange problem on my zed rear window heater switch,does anyone no why the bulb that comes on when you switch the de-mister on goes out when you switch the lights on,thanks Mark
Do you know if the bulb has been replaced with an LED or not?
If it has (and it's a white LED), the standard resistor dims the output to virtually nothing when the lights are turned on.
Many thanks for reply,I have replaced the bulbs with high powered blue leds,the twist in bulbs have a 470 ohm resistor fitted,but the two yellow leds already fitted for rear demister and the fog switch i checked the polarity and just replaced them with 3mm blue leds,fog wont light at all ,more head scratching lol.
thanks for info, ive got the polarity right,the led lights up when i switch on the rear demister,but goes out when i switch the lights on,thanks Mark
