P/S electric window
Can't get mine to work, tried a new switch and played about with the on-off switch on the drivers side. Ran power direct to motor and that works, any ideas? Is there any relays/fuses for this? Think it's the last thing to fix on the car and would like to do it before the MOT
I think there is some sort of power amplifier/relay type box thing in the drivers door that is part of the window control system.
Not sure if there is one in the other door, but I don't think so. Maybe this is faulty?
Indeed! Have a look at this thread, seems I was right there is only one power amplifier fitted in the driver door, this could be the problem...
http://www.300zx.co.uk/forums/showthread.php?149276-drivers-window-not-working&highlight=window+amp
Failing that, could it be a faulty driver side switch assembly, maybe the isolation on/off part has failed?
Might be worth swapping out the drivers side switch if you have one, but my money is on the amp.
Edited by lonezedder
