This drip!
Hi everyone
Had this problem for a while now just wanted to pick some brains out there.
I have this drip which is slowly filling up my passenger footwell as you can see from the picture the drip is appearing from the passenger kick panel to the left of the glove compartment. I've so far removed the glove compartment and the panel to the left and the kick panel check targa drain and also ran a hose off the roof but no leal appears have fitted new nylon window washer so window is tight up against door rubber . And I've also removed the left skuttle panel but still can't find this drip. Any other suggestions chaps?, ze7unety.jpg
Run hosepipe on half way up windscreen let water run for 5/10 mins if it drips its your windsreen seal or leak at the front!
That eliminates your door & Targa.
Do same with side door & window.
Only a suggestion.
