am putting the battery in the boot of my car what that's the best route to takes seat and carpet is out will I have to remove the dash is there any best way of doing this
Passengers side sill. Take plastic inner fender off and you'll see rubber gromet at the bottom. You can fish 0 gauge cable through. Don't need to remove carpet just lift one side
Might sound a dum Q! wats the advantage of this?
Just curious:confused1:
Frees up space in the engine bay.
Allows much larger batteries to be installed if you're powering a large amount of ICE.
I have the cable ran into the boot through the same grommet as Rolandas has used, but the cable then runs under the center console. Doubt this would be possible in a 2+2 though.
My move has never been finished though, just the wiring. Batter itself is still in the engine bay.
yes I found it it now in
I moved my bat to the boot as were the battery used to be I fitted the rad overflow bottle there and a washer bottle next to it/ I remover the rad overflow bottle and washer bottle and carbon canister as there far to close to the rear of the intercooler so now its all free for the air to flow throw them with out hitting a wall ie bottles
yes there is far to much crap in that bay
I'm having the wings and bumper off this winter to delete the guff under there and simply the power steering system this winter. I do not need a massive washer resivoir or expansion bottle. BIN
