Solved - Heaters / Air Vents Not Switching To Demist
OK I mentioned this on another of my threads
When I went down to the Coventry meet last week, the air vents in my car were stuck in 'Auto' position, blowing air through the centre console and door vents and would not switch over to windscreen demist
When I pressed the Auto/Demist buttons on the climate control, the appropriate LED would light and there would be the bleep to indicate it was switching over
Also there was a click from behind the passenger glove compartment when switching between Auto/Demist
While over at Lee Dent's today he had a look at this for me
With the passenger glove compartment removed, it was clear to see an actuator arm was moving each time we selected Auto/Demist
However the air flow through the vents was not switching
With the cowling over the dashboard clocks removed, Lee had his hand down behind the left Binacle and there is another acutator here which directs the air flow
The problem was that part of the wiring connected to some sort of controller box was fouling the actuator so it could not move.
With the obstructing item moved out of the way all worked fine.
It's quite apparent now that I introduced this fault myself when I had the dash clocks out last year to fit reverse indiglow dials. I pushed the wiring loom out of the way while refitting the dash and obviously fouled the air vents mechanism. As my car was off the road from AUtumn last year until May this year I never spotted the problem.
Anyone facing similar issues hopefully now has somewhere to look for the cause
Thanks for the help Lee :flowers:
Rich
Edited by dicky96
speeling
Nice one! Always good to have a history of problem solutions for people to search and learn from in the future. It would be good if everyone finished their problem threads with their solution.
I've certainly learnt plenty on here.
Cheers.:)
