Door lock mech. Grrrrrrrr1
Hi. Purchased some metal door lock mechs to replace the broken brittle plastic ones. Fitted them fine but now can't get the door Handel to close fully. Been at this hours now. And even tried copying the other door but now that's gone the same. Seems to be something to do with the big metal arm which attaches itself to the Handel. uploadfromtaptalk1406189470283.jpg
Have you put the passenger side one on the drivers side?
I did mine the day you mentioned it and using the exactly the same metal part with no issues.
They are definitely handed. If you hold up the broken piece that you took off against the new ones then you'll see which is the correct one.
Sorted it! Thanks buddy! Another thing .just went to top up the cars rad water and assuming the filler is on the the right side.... Pulled the stick and it was totally dry. Never checked this beforr and the card never once overheated. So I put some water in and after a while it's just coming out from underneath the car?? Is there some kinda overflow? I checked the rad cap and saw no signs of water either
