Rev counter stopped working/
Any thoughts Guys.
it was working fine, then needle just sank to zero.
everything else seems to be working fine, ive had the dash out checked wiring
Speed sensor on the gearbox is prone to failure and will cause this. The sensor itself "separates". There is a repair write up by Jeff if you search.
lol..
As mentioned it's either the speed sensor or a dodgy connection/dry joint on the cluster..
soldering iron just packed in ffs...
think i need to pull the engine??
Most definitely mate, probably best if you remove the interior as well and the gearbox, rear subframe, wheels and targas. Just to be safe...
They are off anyway steams, I was changing a headlight bulb... lol
That's probably why the rev counter stopped work mate. For best results it really needs to be installed in the car and wired up....lol
soldering iron just packed in ffs...think i need to pull the engine??
it will be a dry joint mate..needs soldering:rofl:
Rev counter gets its signal from the cas unit via the ecu loom, not a common problem to be honest.
Jeff TT
Oh sorry, speed sensor affects the speedo and not the rev counter.....
I think..... Can't remember now. No help at all really. I'll be quiet now.
