Advice needed please
Just purchased a gearbox off kieran on here so I need to know what I need , like gaskets? Or anything else. If the box is dry from oil how much is the total amount required and is there a special way to fill it as some needs to be in the torque convertor ... cheers guys
Sent from my GT-I9300 using Tapatalk
I was informed on here that 3.5 liters was just the amount u put in when you drain the sump but the rest is in the torque convertor. Please dont tell me ive been putting 3.5 liters in the box just from draining? ? Maybe that is my problem? ? That link is the exact guide I follwed groover but when I get this gearbox how would i know if there is any oil remaining in the torque convertor
Edited by leeroy73
I seem to remember there being a damn site more gearbox oil than that, I had to pour about 7 litres in mine.
You are right its 7.7 litres
When you get your new box there should be no oil in the torque convertor as it was removed from a car, it only holds fluid when in situe in the box in the car.
It actually says in that guide, "around five litres will come out" and to fill it with 3.5 litres run it up and slowly fil and check the level.
Ive already bought another gearbox now . But would be nice to know that maybe mine might be ok I checked the oil from cold and from normal operating temperature and th level is just on the top of the alloy marker...
Which means that is ok? Ive only put 3.5 liters though.....
