2014 work in progress
Some of you may know I have an FB page documenting my progress, but since a few don't have/want FB, I'm going to start uploading pics here too as I get time.
As I've said before, not competing this year, time is being focussed on family and home projects, both of which I largely ignored last year! I also enjoy modifying and developing the car as much as driving it, so can tinker away at it through the year, so don't expect fast progress.
Open for discussion, criticism etc :)
Edited by jaffa
  • Replies 258
  • Views 25.6k
Nice work James! I am sure I'll see the car at Jimmer's some-point-soon!
NIIIIICE !
Id love to build a zed into a dedicated track car, but all my spare cash goes to other things :(
New Rad arrived, stupidly excited about this - it's a monster!
ducted Dual 16" spal fans
Dual-pass design
Integrated oil cooler with -12AN connectors
Will that actually fit in the boot ??? :)
looking good James
Dual-pass design
I was looking at that rad and thinking, that's way to wide. Then I remembered the pictures you showed me a while back.
Hi, where did you get all your connectors and contacts for your wiring loom? I have some aircraft grade wire (nickel plated copper) (lower resistance so a smaller gauge can be used) but I haven't found a decent supplier of the contacts. On top of that, this build is great - I will keep following. :)
No TOTB for me this year, still too much to do before then.
Marc - I used polevolt.co.uk for the rewire
my SZ order arrived so new fuel rails, injectors, pumps, intercooler and a few other bits. I now have no excuse but to start putting things back on the car. Pics to follow as I work my way through items, need to get the pumps fitted first and tank back on the car.
In the mean time, a quick pic of the intercooler quickly mocked up even though it was going dark!
Strange intercooler arrangement, what's the story there?
Very short piping for response and less pressure drop
Vertical core on the IC, again for less pressure drop.
IC close to engine for shorter piping and reduce weight over the nose of the car
It's customised TDM-works item with matching pipework and with a bit of luck will still clear the DrySump pump
Cheers for the info, Jaffa. I can get round to making mine now. :)
Thanks Bob!
Fuel tank bulkhead finished!
This arrived too, a lightweight Alternator mount
DS pump mounted
and some daylight pics of the FMIC with DS to check clearances
  • 3 weeks later...
small bits of progress
Fuel tank refitted and lines connected up
more oil lines done
Plenum modified for top feed rails and redundant bosses removed since I had the angle grinder out (!)
IACV removed and blank made up
and decided how to do my coolant routing so new connectors added to water pipes and rad
Some more pics of parts being mocked up, and a few parts painted since they're off and I'm too lazy to keep polished parts clean
Also fitted the new lower plenum (needed for top feed inj), now need Jim to pop round to remove crank pulley and refit timing belt!!
Would it not make life easier if the rad was flipped so the take offs were facing downwards, less bends to think about. Unless of corse there is a reason for them to be this way up.
