Some of you may know I have an FB page documenting my progress, but since a few don't have/want FB, I'm going to start uploading pics here too as I get time.
As I've said before, not competing this year, time is being focussed on family and home projects, both of which I largely ignored last year! I also enjoy modifying and developing the car as much as driving it, so can tinker away at it through the year, so don't expect fast progress.
Open for discussion, criticism etc :)
Edited by jaffa
  • Replies 258
  • Views 24.5k
Main goals were to lose more weight from the car, fix some gremlins, and generally make it more track orientated
Winter started with a rewire, from what was an already trimmed loom.
This lot went in the bin
These arrived
cue lots of winter nights starting at wires, diagrams and crimping!
I took a dremel to my bonnet to shave a few kilos
started like this
In progress
done
then added rear aerocatches
My old bumper was worse for wear after my incident last year, CarMad made me a new light weight one
unpacked
pick these up cheap from another forum
Lip attached
cannards attached
and wings attached (which is giving me other ideas
In the last pic you can also see the shell I picked up from HellRaiser, that was a fun morning and thanks to Z32Bolt for lending a hand. The shell will be used as a donor to fix my rear qtr at some stage
Decided to drop down to an 18" wheel since there are better track tire choices available and to save a weight. Finding a lightweight wheel that fitted over my brakes was a mission, settled on these Enkei's. 18x10 all round, and a pair of 17x9.5 for drag racing
Old set vs new
Still very tight, had to grind off a lip to stop them catching the caliper.
and having new brake bells and caliper mounts made to move the brakes further inboard.
fitted (with no brakes)
I bought an angle grinder, how did I survive before that! Various brackets removed, holes in the boot etc
found a space for the new oil tank
here's the matching sump test fitted to an old block
also had to fab a mount for dry sump pump using the AC mount
New mount is being made out of billet based on the original hack job!
and finally, some cooling updates
Naca ducts for air coming in
mounting them
rinse and repeat for other side
air goes out here
and mocking up new rad position and size
This rad is on order, twin 16" fans, double pass with oil cooler in the other end tank
eagle eyed will notice I've lost my rear subframe. Z32bolt now has the old one, new one to be put together and details to be shared in due course
Edited by jaffa
I think the hybrid system will wonders mate, I heard Ash has been experimenting with the very same lawn mover.
yesterday's work was moving the pass seat further back and relocating the extinguisher
Liking the pics. I take it the bumper and wings off the car were making you think of a removable front end for ease of working on your zed?
pretty much, it's a nice idea, and I've figured how to do it with just 2 more attachment points beyond the bonnet aerocatches. Downside is that it will need 2 people to remove safely
Oooo please do a lift off front :) how was the removal of the bonnet support simple yet effective.
simple enough, don't recommend for general use as it's a floppy thing now, weighs nothing as a result so a success for my intentions
Will you do a 'how to' on it? Used to have one on my mini and it was brilliant for getting around the engine to find any leaks (not that minis are hard to work on) also saved a lot of headaches from smashing my head on the bonnet
Also couldn't you put struts/hinges on it so you can flip it if by yourself?
Edited by Wilks88
Nice work Jaffa and great pictures. Had a second 300 few years back intending to do similar, as coombe race track is just up the road thought it be fun to track day, but running a business and having young family and doing house up time just isn't available.
I see your in Bath area so must be close to me, am about 2 mile from bathford/batheaston near Village of Box.
Wouldn't mind having a look some time if that's ok, it might tempt me to find that extra time..,lol
welcome to pop in, I'm on the batheaston side of the A46/A4 roundabout, so very close :)
I could, but I don't think it'll be suitable for most Zeds, I have pretty much nothing behind the bumper area so lots of space. Hinges will add weight and have to be special/complex to avoid catching the splitter with minimal ground clearance
That is 2minutes away literally...lol. Am just waiting for my broken foot to get better ( 2 months :sad:) then perhaps pop down for a nose.
Keep the pictures coming liking this.
  • 3 weeks later...
Since the rear subframe is off, I've dropped the fuel tank, removed all the lines and current fuel system ready for the new setup.
tank off
lines off
pumps out
inj, rails & lines out
modifying the tank bulkhead for new lines, starting with taking the old ones off
lots of cleaning up needed on the underside to make it flat for new connectors
  • 3 weeks later...
