WANTED, auto trans ECU pinout
Hi all,
I need a photo or diagram of the auto trans ECU pinout, not the main ecu.
many thanks
Hello mate,
I want to check all the solenoids in the automatic gearbox from the automatic ECU harness for continuity .
Thanks Groover,
that diagram seems to be missing a section, what im trying to do is a resistance check across ground and each of the pins which are pinouts 5 - lockup solenoid , 8 override solenoid , 6 shift A 7, Shift B , 1 line pressure solenoid 2 drop resistor solenoid.
On the component locator which you kindly sent me on the left hand side of the diagram 5th one down A/T control unit A-C 20 is what I need . the diagram only goes as far as11 is there another page mate?
Ok friend of mine knows someone that can plug my car in but unsure if its consult. He has the correct plug but This was his message which I dont understand can someone shed any light on this or will this not work? " Only problem is, I have that for the solus, but can't find it for the launch, can have ago if you like"
Sent from my GT-I9300 using Tapatalk
