round 2 time for front sub refurb info needed
as you know I have just finished refurbing my rear sub frame am now doing the front sub what I want to know is what bushes do you need I used e.s bushing in the rear sub I so what bushes and ball joinst can you buy I see I can get the steering rack bushes and role bar bushes what other bushes are there to change were can you get lower ball joints and what about the up rite king pin bit there is some kind of rubber and joint in that ?
no one know then ?
Not many people seem to do it. Il tell you what I plan to replace if that helps?
Lower arm bushes,
Adjustable upper arms,
Steering rack bushes,
Engine and box mounts,
Steering rack bush,
That's about it I think....
Tension rod bushes are already done and my steering arms are new from last year. So yeah that about covers it I think.
am going to do drop links rack bushes and roll bar bushes track rod ends maybe and lower ball joints I have upper adjustable arm and tention rods
Lower arm bushes,
Steering rack bush,
What about the steering rack bushes? :)
it says steering rack bushes in his list
Oh yeah, you did mention the steering rack bushes. I saw that you mentioned the steering rack bushes, but thought that you neglected to mention the steering rack bushes. However, after a second look, I have since observed that you did indeed mention the steering rack bushes. I guess I need to sharpen up! :lol:
fook me lolol :lol:
there is some kind bush/ball joint on the up that is that the king pin ? can that one be replaced
