PTU input and output voltage Question
Hi guys i have a question about the PTU,so i tested the connector which goes into the PTU(seven pin connector)and i got 11.8 volts on six of them but on one end one i get nothing?I am guessing it should be 11.8 volts also.Should it?Also guys what voltage should i be getting out of the PTU,and how can i test it.Cheers guys
Power is transferred through it, think of it like a splitter block. So if you unplug the side that's feeding it you won't fervent voltage, you've in plugged it.
You measure as a power diode, put your meter on diode check one way measure about 950 ohms swap the leads you should not get anything.
this is measuring on the ptu only.
Yes i did that mate and i got 1.4 ohms and none by swaping the leds over
