OMG i have yet another problem
Hi guys,so i got rid of one problem and now i have a new one,When i started the car first i was getting clutch and was getting the gears no problem,but now i cant even press the clutch had as a rock,would it be the slave cylinder as it cant be the master cylinder as i replaced it 2 years ago,any advise would be great,sorry for posting all these problems:pinch:
Yes i think so,not 100% sure as i bought it from japan
Oh its a TT
Ok well I would pull the slave personally they do jam up. Mine did but then freed up. New ones aren't crazy expensive, that and changing to a braided line could be a relatively cheap bit of upgrading/maintaince. You be able to work it loose on the bench.
My clutch is uprated and so stiff without the servo assistance. However you can depress it. If yours is rock hard not moving I'd say it's more likely the slave.
Ok thanks mate,i will take the slave out tomorrow just to make sure.Thanks again
They don't like sitting around. I would expect a few niggles to come yet...sorry.
