Help needed with stubborn front drop link nuts
As above all, trying to remove the N/S front drop link managed to get one off the nuts nearly all the way off then the inner one started to spin in the spanner & is now nearly rounded off. The one at the ARB end isn't budging :-(
Any helpful tips or advice?
Cheerz
J
Get the grinder to the bolt head (carefully)and cut off:)Where goggles and gloves of course
Has above cut it off when i do anti roll bar links at work I use an air gun and instead of undoing them I do them up, couple of seconds and the bolt snaps clean off...
Saves getting a couple of turns and then it spinning and using mole grips to hold it or cutting it with the grinder...
Edited by Terry
