- Replies 62
- Views 11.4k
- Created
- Last Reply
On 20/08/2024 at 20:41, RichardS said: Hi, I posted on this in another thread, as I have had the same problem previously. Chances are, your auto 'box is dead - so you have three
Hi, just Got the car back up and running after a gearbox change, previous box showed signs of internal damage ie intermittent gear selection problems, but what ever the problem it would never get out of 2nd. At the time i never checked fuses, Gearbox ECU etc.. i was told the box needed changing and took it on faith. However , now the new box is installed (which was taken on faith yet again it was fine) when i took it out for its first run, it would only use 1st and 2nd in D mode. i have recently had it pointed out that the problem might be external to the box ie the fuses, Gearbox ECU, etc...
So i have found out how to put it into diag mode, which i will try soon and give the results, i found this site
http://z32.wikispaces.com/Automatic+Transmission+Diagnostics
which looks great anyway in case anyone hasn't found it yet. i know where the Gearbox ECU is located but need to know if the GB has any fuses that blow and if so where are they
I cant think of any other issues that might affect the smooth running of the box but again, if anyone knows better please advise.
Another question, when i press the overdrive? button, a light illuminates on the RH set of warning lamps called "MISSION OIL" (i think it means transmission oil) has a wire gone astray? have i somehow got a rogue dash unit.
Kind Regards
Rich
