Auto Gearbox problems
- Replies 62
- Views 12k
- Created
- Last Reply
My car is having a manual conversion done in october. My autobox is currently on 56,000 miles and has been well looked after. More than happy to sell to you once its out.
Hi, just Got the car back up and running after a gearbox change, previous box showed signs of internal damage ie intermittent gear selection problems, but what ever the problem it would never get out of 2nd. At the time i never checked fuses, Gearbox ECU etc.. i was told the box needed changing and took it on faith. However , now the new box is installed (which was taken on faith yet again it was fine) when i took it out for its first run, it would only use 1st and 2nd in D mode. i have recently had it pointed out that the problem might be external to the box ie the fuses, Gearbox ECU, etc...
So i have found out how to put it into diag mode, which i will try soon and give the results, i found this site
http://z32.wikispaces.com/Automatic+Transmission+Diagnostics
which looks great anyway in case anyone hasn't found it yet. i know where the Gearbox ECU is located but need to know if the GB has any fuses that blow and if so where are they
I cant think of any other issues that might affect the smooth running of the box but again, if anyone knows better please advise.
Another question, when i press the overdrive? button, a light illuminates on the RH set of warning lamps called "MISSION OIL" (i think it means transmission oil) has a wire gone astray? have i somehow got a rogue dash unit.
Kind Regards
Rich
