February 9, 201411 yr were is the best place to buy some rear lower ball joints the oem ones are just to expensive
February 9, 201411 yr were is the best place to buy some rear lower ball joints the oem ones are just to expensive Do you mean the ones on the wishbone? If so, it's a lot cheaper to buy a pair of second hand wishbone's than it is to get the ball joints replaced. They don't normally wear out like the other balljoints do, so if you get a good set then your laughing.
February 9, 201411 yr yes the wish bone ball joint mine are fine like but I have the rear sub out and the whole thing is getting refurb so was thinking of changing the ball joints while its out
February 9, 201411 yr I'm not 100% but I don't think nissan do them as a single item... I know a company that has had some modded to the the same fit.. you could speak to them if you want.
