Wheels from 350z
The rays do. Though the tyres need changing to maintain rolling radius.
Dan had a set for sale recently.
They are like a deep dish mesh style if that helps
Er......no 350z I know came with mesh wheels as standard. And I'm a moderator on the 350z forum.
UK cars came with either 6 spoke standard wheels with curved spokes. Or the 6 spoke Rays.
Or the 5 spoke GT4 specials.
Put a pic up.
They're aftermarket wheels and they'll fit. PCD, Centrebore and general offsets are pretty much that of the Z32. Do you have the specs of the wheels? Required are diameter, width and offset. Can advise on tyre size then.
225/45/18 and 245/45/18 for the rear. Thanks for all the help fellas
I would echo be careful on the rear, they can go much more aggressive under stock arches
No no those are tyre sizes and they appear very skinny. Wheel dimensions are required. How wide are the wheels and what offset are they? Widths will vary between an 8j and higher generally.
They look very similar to my aftermarket wheels - as Si says, they "should" still fit the Z32 but regarding tyre sizes, I have 235/40/18 front and 265/35/18 rears.....
Can't remember the width and offset of my own wheels though...:wink:
PCD front 112
PCD rear 114.3
What tyre size would I be looking at.
The fronts won't fit.
PCD is 114.3 on all four corners of a Z32 (and a Z33 for that matter, so fook knows why the fronts are that PCD!)
Cheers Lexx I will have another look when in the unit again tomorrow
