Clutch Alignment Tool
I'm close to putting my OS Giken twin plate back on the motor, does anyone know if I will get away with a universal tool for a twin plate or do I need the OSG specific item?
you would proberly need another identical plate spacer insert or idealy a longer one to hold the 2 plates....iff you can give me measurements as in length and OD plus ID then i could make you one on my Lathe:yes:
That would be most awesome! I understand the length and ID measurements you need but what OD do you need?
i need the diameter of your bar from the kit...the ID of your clutch plates and the length you need the insert
