can I change the seat belts from door mounted to uk spec??
Hi guys,
Just bought a z32 and see it has the seat belts in the door and lap belts in the rear. I was playing about on the bay and seen quite a few zx's with uk spec seatbelts on the chassis of the car and proper seat belts in the rear for the kids.
Can these be changed about as there is a few sets on the bay but reading one listing, and they say its not possible to put the uk spec into the import model?
Thanks as I don't want to take it to bits to find out they aren't compatable.
regards
Derek.
I've done it but the captive nuts are not in some of the holes.
Rear belts bolt straight in, fronts I had to cut a slit put a big washer with a nut on the back, And weld it.
Ok if all interior is out, sure u will need the rear quarter and door cards too.
Hi, I thought it was going to end up with a bit of hassile to change them over. Hopefully some off the breakers on the forum here may be able to help out at a reasonable cost. I'm taking out the interior as its rotten and really needs to be updated. I have my upholstery guy calling on Wednesday to change the carpet inlay to leather and recover the seats. So the door cards and rear trim may be useable?
I've got both the fronts and rears from my UK car, you may have sent me a message through eBay?
