another question
think im being a nuisance today i have some brembo 4 pot calipers fitted on the front with grooved discs htink they were off a skyline time has come for some new pads but dont know what to buy re size etc can anyone help or point me in the right direction please
the calipers are black if thats any help
let my buy them of you then ill let you know.
need pic i would have thought
Ok lots and lots of choice, however make the wrong choice and you wallet will groan....
Worse choice:
Nissan UK
Standard fit Nissan boxed pads to fit a R34 GT-R Brembo calipers £290 OUCH!!!
Not so bad choice:
EBC Red stuff
R34 GT-R Brembo calipers £102.80 ( Demon Tweeks Direct ( E-Bay) )
Best option:
BMW spurious brands:
Little known fact is the BMW 8 (E31) 850 also used the same Brembo calipers, as a more main stream car than the GT-R the spurious suppliers can do a better deal, so look for the BMW fittment instead and the prices then start from £36.16 ( LINK BELOW)
http://www.micksgarage.com/proddetails.aspx?pid=426260&pk=ff568
Ran a set of spurious BMW pads in my Brembos for 4 years no bad pad wear or dust and brakes pin sharp feel, cost me around £35 at the time....bargain without compromise.
Hope that helps.
Jeff TT
...................Little known fact is the BMW 8 (E31) 850 also used the same Brembo calipers, as a more main stream car than the GT-R the spurious suppliers can do a better deal, so look for the BMW fittment instead and the prices then start from £36.16 ( LINK BELOW)
Hope that helps.
Jeff TT
Very interesting Jeff - I assume that means BMW sourced calipers can be used as a Z32 upgrade; given that the GT-R ones can be hard to come by......
.....Although the 850 is not exactly common-place either...:wink:
Great advise though mate!!
Richard:cool:
Worse choice:
Nissan UK
Not so bad choice:
EBC Red stuff
Best option:
Hope that helps.
Jeff TT
cheers Jeff it just so happens these are the calipers and discs i got from u some time ago they came off a black 300 u had in the shop at the time because u took them off while i was down having some work done
also got the front panel off the same car in dark maroon
