What's next
I haven't done anything performance wise to my car yet it's had a zed world ecu so far. Looking at cat back exhaust and single air filter come as dual is pointless unless running high bhp. Also looking at getting interior trim kit to match car colour and new seats but don't no if I would have to modify rails. What else do you all suggest open to any ideas.
ย
Do55bag
  • Replies 29
  • Views 1.5k
Hicas is simply a means to create a far sharper turn in like a lightweight small car. It makes the car extremely good at slalom work and was designed around the overtaking manover.
Sadly most peoples don't work properly leaving is loose and sluggish. Dependant on your desires, as a track driving propersition or for drifting it can make the car hard to predict as often it causes you to over correct. I've had that a few times leaving me fish tailing and scrabbling at the wheel. It's also speed dependant so don't expect the same results each time.
In short hicas takes a lot of getting used to, and even then it can make driving on the limits of grip hard to second guess as it creates a floaty feeling as if it's about to go.
If your car is purely to waft along in and occasionally over take and it works, you will probably like it. If you wish to drive harder it's unpredictability will cause you to loose patience with it. It's saved my bacon and caused me heart attacks equal amounts of times.
ย
Do55bag
ย
Why do you feel this to be the case? A Selin Dual MAF Translator is a worthwhile mod even on a car with just an improved exhaust system.
ย
that's does make sence I agree 100%
Just something I've been told buy a few people
