Help?
Transmission problem? Been driving her every day for the last month with no issues got in today and noticed a whinning sound coming from the auto transmission was fine yesterday does this mean its on its way out or could it be a top up? I know that gearbox oil shouldn't really get low unless theres a leak, this has just happened overnight which I find odd, hoping its something simple and not a gearbox :(
Sent from my GT-I9300 using Tapatalk
  • Replies 34
  • Views 1.5k
is there a way i can post an audio clip on here? id like to post it so you guys can have a listen ......
ok will do, the reason im gonna have to upload this is cos ive spent the last 2 hours trying to get this diagnostic thing to work, i have no A/T light anywhere on the car whatsoever, so i cant read any codes even if i did do the procedure correctly..
Its following the revs and could be either the alternator, AC pulley or power steering pulley. I would disconnect the aux belts, then start up again if the noise has gone then you add one a a time, alternator, ac and then PS pump to determine which one. I could be wrong as its dificult to tell sometimes on a video, but it sounds too close to the engine to be gearbox related.
Thanks for the input groover, at first i thought it was gearbox but when i noticed the noise while idle and it goes after about 2 miles i thought maybe alternator,, ill have a look tomorow. thank you all for your help been fab ;)
