Can I just run this past some way-more experienced eyes? :bow: Just to see whether I'm working this out right for the Rota Grids (18s) that I was looking at.
Working from the standard sizes [Front 16 x 7.5 45mm Offset and Rear 16 x 8.5 35mm Offset] I'm thinking for 18 x 9.0 Fronts with an Offset of 25mm and 18 x 9.5 Rears with an Offset of 22mm would give the following;
Front Inner Clearance of +1mm and Outer Position of + 38mm
Rear Inner Clearance of -1mm and Outer Position of +26mm
IF that does sound right, would the increase of Outer Position warrant any arch rolling / flaring do you reckon? I'm thinking that it wouldn't but hey, I'm still relatively new to zeds.
Hi Chaps,
Cheers for the sense-check :thumbup1:
Nick
