Noticed my rear screen had molten metal marks in the glass forgot to cover it when we welded the holes up what the spoiler left behind . Don't suppose I can get these out how much is a rear screen for these haven't got it insured at the moment as it's of road doesn't matter if is a uk screen it has dark tint film on .which I know I will need to replace thanks Taff
Brand new they are £850
Second hand, buy a rotten tailgate with one in and have a windscreen company swap them over. You'll likely need new trim around the bottom, which is about £90.
Taff
i have a good window in a rotten tail gate if needed
edit ... i see your car is SWB .. no i dont have one
Have you been down the scrappy yet to get that other bit off my old Zed mate?
Only ask as that still had the glass in good condition in it.
Although not sure if the swb and lwb rear screens are the same size.
They're different.
Taff, I do believe that Jeff has one. He has Sir Charles' old SWB that was flood damaged. When I was down there last (a few months ago), the tailgate and glass were still on the car.
Is it fairly easy to keep the upper, more expensive trim?
Yup, mine is still the original upper trim. As long as the screen guy knows what he's doing, it can be saved. It's molded plastic over a metal structure that's clipped in.
Thanks guys had a few offers of rear screens i know a local glass guy so hopefully can save the trims .
YOU MUST SAVE THE UPPER TRIM.
SWB one NLA from Nisssan.IIRC
2+2 version not long enough.
Been there... done that etc......
To get the metal out rub a copper coin flat over the glass it will still be pitted but it wont have rusty metal on it.
Ok thanks will try that tip with the coin .
