two things ?
before i go done the route of fitting buying another electric ariel is there a relay somewere for this or is it just fuses that i need to check cas it dont work and there is a live feed to it.
secondly can anyone point out to me the relay to buy for the indicators that i can replace for slowing things down when fitting led bulbs.
cheers
Andy, the indicators on my shortie have been changed to LED's along with the side lights, the indicators flash very fast as if there is a bulb out, do I need the relay
you talk about to give them a normal flash rate? Cheers Andy.
I just left two original bulbs connected in the rear of the car (but tucked out of the way behind the trim so you don't see them) and then plugged in the LED ones and jobs a good un!
Rich
Rich
That's because you want to save yourself £2.00 !!
BTW I have that many leds come on when I signal that I don't need a fast flash relay :whistling:.
cheers mate jobs a goodn just ordered it one pound twenty five pence.
cheers guys just the arieal to sort out now.?
could it be stuck mine used to get stuck dirt builds up on them so you need to keep it clean, try turning the radio on then going to the aerial and manually lift it as the motor to it comes on .
There is a control box for the aerial; just inside the inner right hand rear wing - behind the boot trim. It is a white-ish box about the same size as a cigarette packet!
How much. And is there a way of testing them to see if its something else is wrong cas it used to work.
Yes....stick 12v directly into it and see what happens !!
Never had one on the bench nor have I ever had an issue with mine but I expect there's only about 4 wires, one will be ground and one will be positive lift and another positive retract, so go on do it then work back from here.
Cheers mate turned on and off about twenty times and used wd40 then as if by magic she came awake. and now goes up and down as quickly as a whores draws.
thanks guys for saving me thirty pounds.
[/color]
Glad you sorted it just keep it clean all the time.
