G'Box off, List of Parts. What would you change?
Seriously, before the trigger is pulled.
I've done my research, but is anything missed? Anything too much?
It's the old 'Things to do with the Gearbox Off' List....
(The O2 sensors are already new)
that looks good .. but its loads easier to sort out the water pipes and do a plenum bypass with the box off
Core plugs at the back of the engine , they can rot from the inside , 5 min job to change em :yes:
Do the reverse switch aswel, they are cheap here though use an xtrail one it's the same and a third of the price. Also gear stock bushes.
Thanks chaps! All have some rep.
Gear bushes I did a while ago from the top, massive difference, highly recommend it!
For the reverse switch, there are two versions, are they interchangeable do you know?
Did this from the top, but I'll have an old tidy about.
Core plugs. Crikey! Have you got a good photo of the location of the ones on the back?
Edited by olliezx
Isnt this the Rear Main Seal? If so, I've got it covered. Thanks for the tip!
Crank shaft rear oil seal......?
It's probably fine, but you don't want to be taking the 'box out again soon...:wink:
Probably Ollie.....
.....I didn't look at all your pics mate:oops:
Richard:flowers:
Think refresh of master and slave cylinder is in order and new one piece hose.
Surprised nobody complained about the roller bearing? Think I'll probably change that for OEM...
New reverse switch and netral switch added, thanks for the heads up.
