August 21, 201312 yr is there any way i can turn the hicas off just like temp is there a fuse or maybe clamping the lines i need to just stop it form working so i can see if my car stops pulling to the left
August 21, 201312 yr hi mate, next to the main engine ecu in the passanger footwell theres a smaller ecu for the hicas has 2 connectors going to it... if u unplug 1 connector it will make the steering heavy plug that 1 back in and un plug the other that will keep the speed assisted steering but disable the hicas... hope that helps... if u are still unsure tonight i can post a pic of the ecu and connectors.
August 21, 201312 yr yes if you have a pic that would be great i wont be working in the car till to moz i just need to see if the hicas is the cause of my car pulling t the left
