Cam covers powder coated
Just a quick survey as I'm nearly at end of building my engine
I had the cam covers prepped shot blasted but the guy said it would melt the plastic bits inside the baffle the oil drains
So who's had em powder coated and did ya just leave the plastic drain pieces drop to bits
Regards rich
had mine done and have now had them on for 2yrs with no problems at all.
Yeah if you look underside ul see a few drain tubes crimped inside baffles made from plastic
As well as the risk of shot blast sand stuck inside corners and the breather tube that is press fitted in which may become loose
Just weighing option up before engine goes in
Rich
