car pulling to the left
i had the tracking done 2 times now and the car pulls to the left anyone had this issue and how did you resolve it
How bad is it pulling to the left?
is your car lowered?
All my cars that have been lowered all pull to the left slightly, but usually its just the camber of the road and nothing to worry about.
its stock set up
kind of like you have to have the steering wheel turned to the rite a bit all the time to stop it
i just parked the car up for 15 mins the brake calliper on the rite you can touch it its warm but the brake calliper on the left is still very hot and will burn if you touch it for a bit. jacked tha car up the wheel turn there is a little resistance tho think there is somthing going on with the calliper could do with a old one to swap it it with see if that fixes it
Could be a stuck piston or your rubber brake pipe has split on the inside and acting like a one way valve. The hotter your brakes get the more the fluid will expand and push the pads on more.
went out for a drive still pulls to the left both wheels turn ok when jacked up i will buy a other jack tomoz so i can spin both wheels at the same time to see if there the same i was thinking before the other on had a little resistence but now i think there the same looked at all bushes now are shot tyres are the same psi to
this is before and after tracking rear camber is out and front rite is out to could this be why is pulling left it dont seem much out Image15.jpg
yes if you drive on a total flat road its goes left am drivining round with the wheel at about 1 oclock to make it go straight
do you have the same tires on front,dont mean size but make
yes there the same .with the same psi. should i buy ajustable front and rear camber arm to get everyting in spec? is the rear camber ajustable
i had this on my last zed...middle of road no problem but as soon as i moved over ide get a very slight bias towards the kerb.
this is pulling on total flat road is you loook at the print out the rear and front camber is out like but am not sure if that enuf to make it pull left
