Running in chip - Noz?
Hi
Could Noz help me in getting a running in chip the has no boost so I can drive the car up to his to get it mapped please.
I have a standard ECU.
It will need a socket too. I'm really good at soldering and when Terry finishes my Z Monday or Tuesday this week.
Probably going to start it and make sure all is ok but won't move until this chip is in.
I've got uprated gt525's on there and don't trust the boost in run in.
Millers running in oil is in it also
They're Wiseco pistons bored, honed, acl big and main bearings.
Everything is new and rebuilt now.
ANT
Hi guys Im putting the engine in for anthony..
im not to good with this performance stuff,
His got gt525 and his running a standard ecu.
even though his only running standard boost until its run in and been mapped.
will 9psi on gt525 be like running higher boost.
will he need a map to drive it to the cars run in and then take it to noz for mapping.
Any help appreciated.
Don't quote me on it but you will process more air at a set psi. If that is the case then on boost the car would run lean even at 9psi. If it was me I wouldn't boost at all until I knew for certain it was correct.
I can provide a basemap for you, no problem there at all :)
I built Joely P,s to that spec,hes running stock boost safely at 9ps! and it made 369 fwhp at surrey rolling rd.
I can't read PM's for some reason.
because you're not subscribed
Can you send it to Terry Cheers
Yes, I sent it to Terry :)
Noz.
Tezza said you wanted my spec list.
Bore Size: 87.5mm (.020" OS) wiseco pistons
Acl big and main bearings
Rods are standard
All gaskets brand new oem inc head gaskets
New water pump
All silicon pipes
New thermostat
New cambelt
2.5" totally decat exhaust
Divorced japspeed downpipes from turbo back
Brand new gt525 tubs
I'll pay you £ for the temp chip.
Going to socket my ecu to put it in.
Soldering is one of my skills ;)
What will this chip do?
  • 5 months later...
