Rear Quater windows and.....
Can someone help?
How do you remove the rear windows. Do they have to be cut out or will a heat gun and patience help to remove?
Also, has anyone ever removed the rear wing/ quater panels and seals from a shell if so, where did you cut from-to and are there any formers/stringers to be aware of? I want to save these parts for a future project/spares?
Cheers.
Yes, the 1/4 windows need to be cut out. They're bonded in with windscreen bond. Cheese wire and plenty of lube to cut through it. Takes some time and patience. I've removed a few of them.
Just done mine a few months back, an oscillating flat saw helps too ;)
