n/a - tt pull and swap
Ok so ive got ades zed (thanks buddy) and im picking it up at the end of the month the main job I want doing is a tt swap with a man gearbox upgrade from auto ofc. How much am I looking at to have this done by either someone on here with the skills to do it to a high level or zworld? Or is this something a good local garage can do. Rather use a zed guy thought tbh as I don't trust people that have not got much experience on zeds. (THERE a pain to work on and I have the scars to prove it)
Hi iam in the middle of swapping a auto for manual it took me approx 4 hrs to get the auto box out by myself I haven't got a lot of experience with Zeds but there is plenty of help on here , will hopefully get the manual box in soon once the new clutch arrives , good luck with your project gaz
its all ways nice to try this stuff you self .. and i know Changing a gear isn't that hard of a job but boy is it time consuming .. don't forget you have to do the wiring/clutch setup and some little bits that makes the job a hole lot more then expected ... but then all so your doing a NA>TT swap that's a huge task in its self change to much stuff at once and it don't work for you like most of the time and you will be stuck
if its something you have never done before i would recommend you contact a garage that is more than capable of doing the job with in a short time frame
