June 26, 201313 yr Hello, I hope You understand what i write guys ;) . My clutch was working before i remove engine. After i put the engine back, I buy a brand nev slave clutch cylinder (old one was leaking) and istal it. Put new fluid into system, and trying to bleed it like in all this FAQ. My clutch pedal is soft, like no resistance at all, all the way. Slave cylinder dont move at all, even 1mm. Fluid is coming out from bleed valve on bottom and this one near driver wing. Why my clutch not working at all? Konrad
July 1, 201312 yr Sorry if someone already said this, I did read through but didn't notice anything. When replacing the clutch cylinder, don't bother connecting the pipe that goes off across the left wing, just make a brand new connection straight down, with either hard pipe, or a flexi pipe (see link below), directly to the slave cylinder, then bleeding is easy thanks to gravity! Simply top up the cylinder, then go underneath, drain some fluid off, until no air bubbles (if any at all), nip the nut, top up reservoir, job done. My clutch cylinder went too, it is a right pain to get out and in, but can be done. Don't expect to have any skin left on your knuckles. I'm sure I've seen one in the UK - http://www.zspeedperformance.com/ZSpeed-300zx-1-Piece-Stainless-SS-Clutch-Hose-Full-Length-ZSP1008.htm
July 1, 201312 yr Author I take out clutch cylinder 3 times allready, its not so hard to be honest :) . Now all i need is to wait till i get my repair kit, and then i hope clutch start to works.
Hello,
Konrad
