clutch
just a quick question :) when i press cluch pedal my car revs 200 rpm more ... there are no switches on clutch pedal ... i start the car in neutral and it idles at 800rpm i don`t change gear just press clutch pedal and revs goes to 1000rpm and while driving every time i press the clutch pedal revs goes up.... any idea why ? thanks
you might have a small leak on clutch booster which then acts like a vacume leak and increases revs
and if it`s not connected ? :)
You say its not conected is the bung in the hose blocking it off not leaking air .
