Got a feeling my clutch Master Cylinder has broken. All fluid has drained away and clutch pedal has no pressure so very easy going to the floor! Even easier when engine running!!
Done a bit of searching on the internet but can't seem to find one for my Twin Turbo anywhere...
Can I use an NA one or are there any other Nissan's that use the same Clutch master cylinder?? Just to note I did away with the clutch booster years ago so always had a heavy clutch.
Â
Also is it easy to get hold of a repair kit for the clutch master cylinder?
Â
Any help on this would be much appreciated! Thanks!
Â
Â
