Want to change your tyres, ?
I was looking around the web when i came accross a tool/calculator that gives you a measurement in percentage to tell you what you should or shoulnt put on your car. Your tyre siezes from front to back have a difference in diameter and is measured in percentage and you shouldnt go above the recomended 2.5%.
Heres a couple of sizes and results that i was playing with.
225 35 18 rear 225 40 18 front = -3.45% rubbish result
265 35 18 rear 245 40 18 front = 1.56% rubbish but within the recomended perameter.
275 35 18 rear 245 40 18 front = 0.46% tonnes better and really low/good but then i got this next result,
265 35 18 rear 235 40 18 front = 0.31% This was best result i could get right accross the board. I was going for the 275 rersult but i belieave im only gaining 10mm on the rear tyres so i think im going to be getting 265 35 18 rear 235 40 18 front.
Out of curiosity, why do you opt for, or what are the reasons for running a lower/different profile tyre on the rear to that of the front?
Out of curiosity' date=' why do you opt for, or what are the reasons for running a lower/different profile tyre on the rear to that of the front?[/quote']
Staggered wheel widths, wider rear wheels mean wider rear tyres. If the rears are wider you need to run a lower profile to match the rolling radius. The 2.5% recommendation is so the speedo stays reasonably accurate.
Tyre profile is a percentage of tyre width. So a narrower tyre needs a taller profile to keep the same overall diameter as a wider tyre.
You aim to keep the same overall diameter as stock to not affect vehicle gearing, and subsequent speedometer accuracy.
Completley understand that, and with 4 wheel driven cars. I know a few Supra owners that run 18's on the front 19's on the back on the same profile tyre???.
I was looking around the web when i came accross a tool/calculator that gives you a measurement in percentage to tell you what you should or shoulnt put on your car. Your tyre siezes from front to back have a difference in diameter and is measured in percentage and you shouldnt go above the recomended 2.5%.Heres a couple of sizes and results that i was playing with.
What i should have said was no more or less than 2.5% + or - 2.5%
That's the combi that many people on here run - I do myself - 265 rears are more than adequate width and it stops before tyre prices start getting silly!!
And Yowser explained the tyre profile/ration thing perfectly.... Nice one mate!!
Richard:thumbup1:
yeah ive got 265/35/18 at the rear and 225/40/18 up front.
I never got round to putting your front size in ill find the site and come back with you percentage?
your size it says they are 0.94% about 6m dif, well within the perameter, but if you had put the same size at the front with say a profile of say 35 same as the rear you would been way outside the peramerters to plus 4.55%.
heres the tool i found. http://www.etyres.co.uk/tyre-size-calculator.htm
